Inner Door Window Trim Seal help
Hi everyone,
Was hoping someone has had experience with installing the inner window door trim seal bead into the channel in the metal trim fitting on the outer lip of the window area of the door.
Pictures of the Metal Door Trim Channel and the rubber bead on the actual inner window door seal.
Figured out how to do this. Very difficult, but doable. I will post after completion the process to reinstall the inner door glass window seal bead into the track of the metal trim.
