Hub Dust Cap Removal
Any tips for getting the hub dust cap off?
I've managed to get one side off using an exaust clamp fitted in the groove of the cap. The other side just does not want to budge.
If you are talking about the cap on the front hub I used a wood chiesel [about 1/2 inch or so] and a rubber mallett to ease it off working circumferentially about 90 degrees at a time.
Regards
Fred
Regards
Fred
Got it. Just needed a bigger hammer. Used an exaust clamp, chisel and a big rubber mallet. Took a bit of a beating to get it off.
Had to fight with a stuck tie rod as well. Left side of the car much harder than the other side was.
Screwdriver shaft ~5/16 - 3/8" dia laid in the groove between cap and hub (parallel to wheel, horizontal) and tapped with a hammer, work your way around the cap.
jp 83 Euro S AT 56k
jp 83 Euro S AT 56k
I just used a big enough bit of metal pipe to make a tool the same as the factory one. Drill and tap for M6 bolts 120 degrees apart, then use a slide hammer.
