928 Forum 1978-1995
Sponsored by: 928 Specialists
clutch brackets
Old 04-04-2015, 09:37 AM
  #31
the flyin' scotsman
the flyin' scotsman's Avatar
I rxd pics of the old and new release arms side by side.........thx Dave.
Cant see much difference?
Old 04-04-2015, 06:59 PM
  #32
the flyin' scotsman
Originally Posted by Rob Edwards
L shaped aluminum channel from Home Despot and a jigsaw. It's ~0.08" or ~2mm thick.
I bought 1/8" as I didn't make me a note to take to store.......too thick (like me at times)!
Old 04-25-2015, 07:41 PM
  #33
the flyin' scotsman
now I have the clutch assembly complete I can share my experience.
My GTS came with an 07 release arm which indicates it was assembled at the factory using a GT model clutch.
As I had bought the newer GTS Throw Out Brg, Pressure plate and clutch plate I decided to also install a GTS release arm.
heres the assembly ready to go back in:
Old 04-26-2015, 12:49 AM
  #34
Hilton
Hilton's Avatar
Cool.. should be very nice to drive!
I fitted the complete GTS clutch to my '89 (pressure plate, release arm, guide tube, TOB etc.) and the action is surprisingly light and easy to use.
I've never been able to get my other S4's to have as light a clutch pedal, despite a correctly set up helper spring, so figure that the combination of teflon bits and new pressure plate fingers is whats made the difference.
While you've got the clutch off, are you replacing the clutch slave or the guts of the master?
Old 04-26-2015, 09:24 AM
  #35
the flyin' scotsman
thx Hilton.........I replaced the guts of the master a few years ago and the slave was replaced a year or so ago........I have also bled the system a few times
The stub shaft in my pics is the uber nice Greg Brown piece
Quick Reply: clutch brackets
