928 Forum 1978-1995
Sponsored by: 928 Specialists
TO bearing side pads
Old Feb 12, 2015 | 09:06 AM
jwillman's Avatar
jwillman
Default TO bearing side pads
Have the clutch pack out of the car. Separated the TO bearing separated and one of the pad attached to the sides that the release arm rides on peeled away from the TO bearing housing.
Is this salvageable? if so whats the best way to reattach those?
Old Feb 12, 2015 | 09:45 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
if the rubber is not oil soaked,
I would clean the surfaces with some acetone,
then abrade them with 400 grit,
add some JB weld ,
and apply a clamp with not much pressure to hold the rubber in place,
then let stand for 24 hours at room temp,
NOTE once this part is installed it is held captive by the release arm and sees minimum movement
Old Feb 12, 2015 | 09:55 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
With the amount of effort required to get to it, I'd suggest calling 928 International and getting a rebuilt bearing. They have new pads made and installed on the original housing.
Old Feb 12, 2015 | 10:18 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
an even better idea^^^ Thanks Greg
Old Feb 13, 2015 | 07:22 AM
jwillman's Avatar
jwillman
Thanks for the advise.
More fun to repair these things than pay someone to have done it for me!
