Tips for restoring stock handling
1986.5 5-speed 928
Lots of good progress bringing my recently-acquired 928 back towards stock looks and street performance. Timing belt and tensioner done, hatch latch working, shifter bushings serviced, heater bypass solved, power seat and window switches fixed, etc. The progress feels good!
Now I'm turning my attention to the car's handling, which feels somewhat loose / floaty / imprecise. I already plan to replace all four shocks and the steering rack, adjust ride height, then get an alignment. Suspension springs are still ok.
While I'm at it, what else should I consider to help bring back stock handling? I'm focused on "consumables" and parts that actually wear out over time, rather than non-stock upgrades to long-lived parts. Tips for how to evaluate what might be worn out and what I can keep would be great.
Thanks!
Thanks!
Replace all the front suspension bushings. Upgrade the steering rack to delrin bushings.
Rear suspension also has several rubber bushings that need replaced.
Steering rack bushings are frequently soft and/or oil soaked. This makes for significant reduction in steering response. Most replace the OE rubber ones with 2 piece Delrin. Roger stocks these. IF the rack isn't leaking, just bushing replacement can make a huge difference.
Rear bushing part names or numbers would be helpful, too.
As thorough as you are attending to this car, you know that before aligning, the car must settle after being lifted. Just checking.
There has not been a lot of discussion on springs and their life span here, but when I was doing my 85, I went ahead and replaced them (I didn't do bushings). It just seemed they are not that expensive and replacing shocks can be challenging and why not do the springs while in there. Just my .02. FWIW, somebody else was doing the job.
Archive Gatekeeper
Here's your parts list for an 86.5 (should be good for 86.5 to 95, come to think of it. )
bushings
bushings
bushings
bushings
I typically do mine every ~10 years.
There will be lots of debate as to what to use.
My personal preference is rubber, slightly stiffer than stock.
once you start getting into harder stuff you will get squeaks and the ride will start to dramatically suffer.
bushings
bushings
bushings
Thanks cretinx, most people seem to agree on doing the bushings if they seem worn. There are several different bushings in the front and rear suspension. Are all of these recommended? Am I missing any?
Front sway bar bushings
Rear sway bar bushings
Rear upper control arm bushings (inner and outer)
Rear lower control arm bushings (inner and outer)
Upper A-arm bushings
Weissach bushings
Weissach bushings
Should one just assume these bushings are needed, if the car is this old? There is nothing about my car's handling that screams "worn-out bushings" that I can tell, then again I've never driven a new one. Other than things like the steering rack bushings, is there a good way to tell visually or otherwise if they need to be changed?
Archive Gatekeeper
FWIW, I didn't include the Weissach bushing (Porsche calls it a 'rocker bar', P/N 928 331 085 00) as they're NLA, AFAIK.
How much of a royal pain in the *** is it to change these, and does it make sense to do it while doing shocks? Shocks are definitely on my list as well...
(Sorry for the semi-hijack...hey, it's still mostly on-topic!)
If you were ever planning on pulling the engine out, though, that would be an even better time since it's so much easier to get to the upper arm mounts.
I'm not sure you can get the upper A arms out with the engine in place. The nuts on the inside of the engine bay are buried waaaay down there and reaching them might require growing a second elbow on your arm.
My hat is off to anyone that has done it without moving the engine.
