Hi there, I'm new to rennlist. I am piecing together a Porsche 928, 1980 4.5l Euro model.
The issue that I have is that when testing the fuel distributor, when "idling" (no airflow, lever arm isn't pushed down at all), the fuel distributor only sprays out of 1 injector with a high pressure (so high it doesn't mist, and you can see the spray pattern clearly), but as soon as you push down on the lever arm then the rest of the injectors spray.
Is this the normal operation of the fuel distributor, and if not, any ideas on where to look to try rectify this issue?
medipedicman: thanks for that, i'll definitely check that out.
LT Texan: they do all spray but only once i start to push down on the arm. As soon as the arm goes up to its resting position (all the way up), only one injector is open, the one right on top of the fuel line to the starter valve.
Jadz928: I have swopped out the injectors, and the same issue occurs. Sometimes though when I swop it out, the high pressure just moves to another injector, normally the one just over the inlet line, but sometimes its random.
Just an update: I tested the injectors, they're all fine and unblocked. I believe the problem lies in the fuel distributor, because I disconnected all the fuel lines that connect the injectors to the fuel distributor, and I sprayed carb cleaner into those holes while the arm up. There was no flow for 5 of the 8 holes, but for 3 of the holes there was a flow that leaked into each other and into the start valve outlet.
Any ideas what could cause that? My guess is that the small o-rings on the inside for the 3 that are leaking into each other aren't sealing.
LT Texan: okay let me clear up the confusion. Yes that is correct, 8 runners and 1 "cold start" injector.
There is no blockage in any fuel lines. Its when the arm is in the "idle"/arm completely up that 1 of the runners is still spraying whilst the rest do not.
LT Texan: swopped out injectors, same problem occurs. So the problem is in the fuel distributor. Where would the problem lie inside the fuel distributor though?
Since the problem did not follow the injector, You'll need to replace the fuel distributor with a new or rebuilt unit. Or rebuild it yourself. There is a link to a rebuild procedure on the link in the second post.
