Idle surges in reverse - 87S4 Auto
Chasing and finding vacuum leaks on my son's 87S4.
Surges really bad in reverse. Neutral and park it is very slight - hardly noticeable.
Any ideas?
Any ideas?
First
Check the vacuum line that run from the engine bay to the transmission modulator valve with a Mity-Vac to see if you don't have a vacuum leak in this line if there no leak there should be issue at all.
If there is a small leak the mechanical action of a small amount of movement (flexing) of the engine/tt/transmission on it's flexible mounts may result in a different size gap in the line
I will do that!
