928 Forum 1978-1995
Sponsored by: 928 Specialists
brake pulsation
Old 01-21-2015, 07:28 PM
polecat702
Vegas, Baby!
polecat702's Avatar
Default brake pulsation
I'm wondering if deposits on the rotors would cause the pedal to pulsate, or are the rotors warped? Seems to me that the rotors a fairly stout, and it'd be very hard to warp a 928 rotor.
What does the forum think?
Old 01-21-2015, 07:39 PM
The Forgotten On
The Forgotten On's Avatar
It is most likely your rotors warping. I had warped rotors on my 81 and had the same vibrating issue. It went away after I replaced them.
Old 01-21-2015, 07:44 PM
Chalkboss
Chalkboss's Avatar
Usually always warped rotors. I agree with you- they do seem pretty tough. Some imports really have a problem with this as their rotors are just crap, and people often over-torque the wheels.
Old 01-21-2015, 07:48 PM
Jim Devine
Jim Devine's Avatar
Unless someone used an air gun on the wheels, I think your problem is pad transfer related-
short article here: Article by Carrol Smith, long time Shelby race team mechanic
http://www.stoptech.com/technical-su...nd-other-myths
Second article by Raybestos-
http://www.hendonpub.com/resources/a...etails?id=1787
Old 01-21-2015, 07:56 PM
soontobered84
soontobered84's Avatar
Warped.
Old 01-21-2015, 09:15 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Easy enough to scuff the old deposits from the rotors with a disk sander or a handy flap wheel on the little disk grinder. Or do another few hard "break-in" style stops, end with a gentle brake application to stop and no hard clamp at the end.
Our cars have floating rotors, pretty much ruling out uneven wheel nut torque as a possible cause; by the time uneven bolt torque would distort a rotor (or hat...) it would, in my estimation, pull the threads out of the nut but only after the cone of the lugnut became one with the aluminum of the wheel. If you can remove the nuts without a holesaw, it wasn't enough torque to do damage under the best conditions.
My late Honda Pilot DD started to have pulsing-pedal issues early in life. I scuffed the rotors, and no more problem. Adjusted my stopping technique slightly, and it didn't come back. The Pilot weighs more, has slightly larger diameter rotors, larger tire diameter too, with less pad swept area. All say it has less stopping capacity than the 928. Rotors are a lot thinner with a lot less airflow redirection for brake cooling. One would surmise that it would have more problems with rotor warping than the 928.
Old 01-21-2015, 09:24 PM
mark kibort
mark kibort's Avatar
its warped.... any hard braking tests would clean up a rotor, and sometimes, if your lug nuts are all the same torque, you can straighten the rotor out. .... ive done this before.
Old 01-21-2015, 10:09 PM
polecat702
Vegas, Baby!
polecat702's Avatar
I'll try the hard stop method first, then the disk sander. Should I go with an after market drilled disk rotor, or replace with OEM?
Thanks for all the feed back!
Old 01-21-2015, 10:44 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,256 Likes on 1,249 Posts
I think Roger has the Zimmerman rotors with the zinc coating,
they last a long time and wont corrode along the edges
Old 01-21-2015, 10:54 PM
bills928
bills928's Avatar
Warped ..... Heat is the enemy.., especially if you use ceramic pads.....If you really want to see that it's warped, set up a dial indicator against the rotor and turn by hand, it should be very clear.
Old 01-22-2015, 01:03 AM
dr bob
dr bob's Avatar
Right on with the dial indicator. Follow up with multiple micrometer readings around the otor. Real warped rotors cause pulsing pedal from deviations in thickness a lot more than actual axial runout.
Bought a zet of "zinc plated" rotors recently for another (non-928) car. Warning on the box suggested that only soap and water should be used to remove fingerprints. No Brake Cleaner. So I used some brake cleaner to wash off the "zinc plating" on the friction surfaces. Turns out the "plating" is more like paint.
Old 01-22-2015, 01:11 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
I'm not saying they are warped or not, but one day at the track I thought the rotors in my 79 were warped (S4 brakes) but it ended up being deposits that cleared up during the next session.
I was running Pagid Orange pads.
Old 01-22-2015, 07:21 AM
Bilal928S4
Bilal928S4's Avatar
If you get pulsation in the brake pedal and the steering wheel on application of the brake, the front rotors are the problem. If you are getting pulsation in the brake pedal only on application of the brake, then the rear rotors are the problem.
Old 01-22-2015, 07:23 AM
danglerb
danglerb's Avatar
Over torquing was a TSB on our Lincoln, new rotors and not letting clowns touch the wheels fixed it.
Given the heat and stress on brake rotors the amazing thing is that they don't warp all the time.
Old 01-22-2015, 07:26 AM
M. Requin
M. Requin's Avatar
I would definitely check this out- had a case with new rotors and it mimicked a warped rotor exactly.
Quick Reply: brake pulsation
