928 Wheel guide on 928 Registry site
I was looking at the site last night and saw that Porsche used the 245/45/16 tire size for both the 8" and 9" wheels (before the GTS wheels). I have the 9x16 D90's on one of my cars and the 245/45/16's look a little narrow to me. what do you think? Is the 245/45/16 the correct tire for both a 8" and 9" wheel?
I autocross a different make car with 275/35-18 BFGoodrich Rivals on an 8.5" wheel. This is considered an "over-tired" combination, but the increase in ultimate grip over a 255/40-17 on an 8.5" is considerable, at the expense of transient response. It works only because the Rival has a very stiff sidewall and the aspect ratio is less, meaning a shorter sidewall.
In a 16" diameter, you are now really constrained, as there are few options for high-performance tires these days.
the 245 recommended rim width is 7.5 to 9 inches, tire width of the bulge of the sidewall is the 245mm when fitted on an 8 inch rim...note that tread width is more like 9.5 inch depending on the tire.
The nominal "size" noted on a tire is NOT tread width but section or bulge width and each tire maker decides what width rim is used for their measurement. So many variables
The stock S4 rear wheel has an 8 inch rim and was kitted with a 245x45x16 so I think you can assume it works just fine. A 9 inch rim will also take such a section and wider if you can find one of a suitable diameter without screwing up the final gear ratio [as other options inevitably seem to do].
Guess it all depends on what you are happy with.
Regards
Fred
Regards
Fred
Thanks for the responses. Looks like Porsche kitted the 245/45 with the 9" D90 rim as well as the 8" S4 wheel. To me the tire just looks weird on the 9" D90 rim...the look where the rim is actually wider than the tire. Does anyone have a GT with these D90 wheels and the 245/45/16 tires? Be curious if your tire sits the same on the rim as mine.
that look is because a 9 inch rim is measured at 9 inches where the tire bead sits on the rim and NOT the overall width from wheel lip to wheel lip. Design 90s being a cast wheel have thick lips to add strength which also adds width. And as mentioned your tread width will vary from one brand to another on the same nominal 245. So you may have the look and reality that the sidewalls splay out to mount on a rim which is wider than the actual tread width but it actually will handle better that way
What Santa said . I have 245 on my D90 9" rims and they do look narrow . However there are very few tires in that 16" size range to choose from , and if you go wider you may end up with a taller tire which will effect the gearing
Received 1,648 Likes
245 is correct - as far as OE fitment is concerned - for the D90 rim.
