928 Forum 1978-1995
Sponsored by: 928 Specialists
Strange headlight problem
Old Dec 21, 2014 | 05:44 AM
yoni_d's Avatar
yoni_d
Default Strange headlight problem
Hi guys,
I own a 1980 928 S European model.
When I got home and turned off the lights, the main headlights had retracted BUT the lights (main beam) stayed on! The lights turned off only after pulling out the headlight rely. I opened the relay and saw some cracks and bad connections inside so I solder it carefully but it had no affect
The weird thing is that when I turn off the lights, while the main head lights retract, the lights are off. When they are fully retracted, the lights comes on again and light the skies.
I understand that there are 2 diodes in the headlight motor but from my understanding, they signal the relay when the headlights are fully up/down and since the headlights are not going into a loop, I assume that they are ok...or maybe I am mistaken?
Any ideas? its driving me crazy...
Old Dec 21, 2014 | 09:54 AM
Ducman82's Avatar
Ducman82
Veteran: Air Force
New relays, then try again.
Old Dec 22, 2014 | 04:40 AM
yoni_d's Avatar
yoni_d
Thanks, As soon as I find one I will give it a try
Old Dec 22, 2014 | 10:50 AM
Alan's Avatar
Alan
Electron Wrangler
If the headlights go up and down correctly then it is not the diodes or the wiring or the motor - so it must be the relay - make sure you get the correct replacement - varies by year. S4+ are not compatible.
Alan
Old Dec 22, 2014 | 04:41 PM
yoni_d's Avatar
yoni_d
Alan
Thanks Alan! I will try to find the exact same relay.
Old Dec 22, 2014 | 07:29 PM
NC928S4's Avatar
NC928S4
Please let "us" know where you source the relay(s). My headlights have occasional psycho behavior despite multiple R&Rs of all mechanical assemblies.
Old Dec 22, 2014 | 07:38 PM
Wisconsin Joe's Avatar
Wisconsin Joe
928 International shows them on their site.
Roger's site is very sparse, you have to call or e-mail directly.
They aren't cheap.
Old Dec 23, 2014 | 08:24 AM
yoni_d's Avatar
yoni_d
I saw in eBay for about 80$ not cheap
Old Jan 19, 2015 | 09:28 AM
yoni_d's Avatar
yoni_d
Default SOLVED: headlight stays on after retract
Hi guys,
After troubleshooting this problem and understanding that the problem is within the headlight massive relay, I decided to try and simply replace the small electronic components instead of buying a new relay. I bought all the components (except the resistors) and started to replace them. I started with the 2 transistors (marked in red) since they were most likely went wrong and...SUCCESS!!!! After replacing both of them, the relay came back to life!!!
The component cost me ~2$ so it is a big save and a very easy job.
Hope it will help you if you encounter a similar problem.
File Type: jpg
Old Jan 19, 2015 | 07:32 PM
RFJ's Avatar
RFJ
Great save,thanks
Old Jan 19, 2015 | 08:55 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Thats a great save thanks for posting,
care to share the part number of the parts you replaced ,
and where you got them
Old Jan 20, 2015 | 12:35 PM
yoni_d's Avatar
yoni_d
The part numbers are written on the components. The transistor part # is: BC337 (write in google "BC337 transistor")
All the components are very basic and can be found in any electric components store. Since I am not from the US I cant recommend here for a shop...
Old Jan 20, 2015 | 02:46 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
2N3904 From Radio Shack should do it. It's a prettygeneric low-power NPN in this service as a relay driver.
