Help with Flex Plate Bolt Part Number
Always amazed what I find on this car... Looks like the PO left off two bolts from the flex plate. I can not find the part number for these bolts, and I am wondering if anyone more knowledgable then me can help out. My plate is still attached, this is a pic I found on the web... But I do need the central Bolts.
Wonder why he would have removed them in the first place.
IIRC, these bolts should also have a serrated surface under their flange to grip onto the clamp body.
I would also use some red Loctite on the threads of the new bolts and torque to at least 45 foot lbs.
They are serrated... Hope I can find them. I think they are part of the flex plate from porsche, and not an individual part. I did find some on the inet. I am not a fan of red loctite, but may make an exception in this case. Easy to heat if they ever need to come out...
Location: Seattle - it's not Hell, but you can see it from here!
as i already had the red loctite for the rear drive plate service bulletin, i had the tech use the red loctite on the front bolts with the SuperClamp install too.
can't hurt.
can't hurt.
You wouldn't want them coming loose and zinging around your bell housing under speed.
Just a suggestion.
Have to agree. Kind of scary in what I found in there... Just glad I looked.
For reference, the Flexplate to torque tube bolt is a grade 12.9 M10 1.25 X 20mm serrated flange hex head bolt. They are hard to find.
I do not see them listed in the parts catalogue.
