14 pin connector
Hi trying to get 88 S4 LHD going bought to part out but to good so will be on the list of many projects . Any way some one has replaced five wires on the loom from the 14 pin connector need to know where they go 1-14. Al so three wires on the oil pressure switch what numbers are they and will it be ok to run with alternator cheers
this is what I have for a 90, an 88 may be different as it has a digital dash, so you will need to check all.
#1 blue. E21 to Alternator Terminal B+
#2 blue/black. Oil pressure sensor Terminal WK to E12
#3 blue/yellow. coolant temp sender to E14
#4 blue/white. oil pressure sensor Terminal G to E22
#5 blue/green to coolant temp sender, brown/green to E15
#6 green/blue. engine oil level switch to E13
#7 brown/green. oil pressure sensor Terminal M to E15
#8 unused
#9 black. AC pressure switch to compressor clutch
#10 green to intake temp sensor, brown/blue to fan control unit
#11 unused
#12 unused
#13 brown. intake temp sensor to ground @ MP II
#14 yellow. C12 to starter solenoid
#8 unused
#11 unused
#12 unused
