Rear Window Trim fix?
I removed the trim on my rear window during the respray of the roof panel and rear deck lid. The clips holding the moulding are now weakened, and allow the moulding to pop-up. I'll push it back down, but it continues to release it.
Can the clips be replaced, or had anyone run into this and have a solution?
Thanks!
Thanks!
the clips are held in place from under the hatch with a single screw and available from Roger.
You will need to pull the trim from the interior of the hatch to access the clip screws.
