Houston guys can I borrow?...
Lon
That would be great, the project is on the back burner until next, NEXT Saturday. Work and holiday guests are getting in the way!
I will email the Kingwood lady about the cam gears and maybe I can swing by your place for the Kempf tool sometime this week or next.
You don't have a flywheel lockout for a 82 do you?
Marty
Marty
Marty, I have a flywheel lock for my 87, 2 hole. If they line up it would hold the flywheel in your 82 providing the splines and shaft lock in. You can stop by anytime just give me a heads up. Also I believe I still have the tele number for the 928 lady at the house, if so I will pass it on.
Lon
Lon
Lon
She did have a set of steel cam gears and a bunch of other stuff she is looking to sell.
I believe there is a small difference between the 83+ and the 78-82 flywheel lock. I think it has to do with the angle of the teeth on the lock.
Anyway, I am getting one from Roger, but I will take you up on the Kempf in a week or so.
Thanks!
Thanks!
Marty,
I have both the belt tensioner and a flywheel lock that I use on my '82 euro if you need to borrow them... (bought the stock wheel from you a while back) the flywheel lock I have has 4 holes in it as well though but worked the last time I changed out the belt and should work in a few months when I need to again!!
I will be in the Kingwood area tomorrow evening for a party if needed.
