they are all sadists........
I have two non speed wrench sets as well (one set of flares that I had to buy to do the fuel system that was another specialized tool job). I have used two at time, but that is about it...
I just did this job. The trick was to support the engine from above so you can remove the cross member and rack. With that done and removing the starter the bolts were a direct access for a small socket and an extension. Seems the trick with these cars is knowing the steps involved in doing a particular job. Now the ones under the harmonic balancer were more difficult. But the good old Craftsman ratcheting box wrench with adjustable head did the trick. Still. Those bolts under the front of the motor took more time than the rest combined.
Chronic Tool Dropper
First time I did this I used a standard combination wrench to get them loose, then fingers to pull them the rest of the way. Car was on a lift, no issues with access for some reason. Crossmember was out for MM's so access wasn't an issue there.
Steven, are you replacing the gasket or just snugging the existing bolts on the existing gasket. If replacing the gasket, the Great Circle Route with the crossmember dropped is actually the shortest distance between start and success. MM's and OPG are WYAIT tasks for each other, IMHO. Each takes the same massive amount of advanced cleaning in my limited experience.
dr bob...
i am doing the both the mm & opg
mucho cleaning.....thats an understatement...
unless you are dwayne.. his cars are always spotless...
For the MM/OPG project, precleaning on a massive scale is needed. I start off with half a case of foamy engine brite, brushes, a power rinse, very tall stands or on the lift, big tarp to manage the mess, catch sump to recover the mess for disposal, and some throw-away clothes under the tyvek coveralls. Even after all that there are places that still aren't clean, like some top of crossmember troughs and the inside of the rack cavity above the protector plate.
For my own cars, engine, transmission, suspension and undercarriage cleaning is an ongoing mission. It's way easier to find and fix leaks if you can see where it's actually coming from. It's not an obsession. I'm not an addict. I can quit any time.
