Automatic-to-manual conversion with 6-speed
A customer dropped off his early '86 32v car to have the 4-speed automatic removed, the car converted to manual transmission, and a 6-speed Corvette transaxle put in.
Here are a few pics, I will add more as it progresses.
First, (of course) the whole automatic transaxle drive-line comes out....
We made a template from a manual transmission donor car of the firewall section we are working on. Here the template is located on the firewall by bolts through the holes for the brake booster. Then we can outline the hole we need to make for the clutch master.
The mount is coated with a bead of sealant, and riveted in place. We used Steel-bodied steel-mandrel rivets. They are rated at 590 lbs shear strength and 810 lbs tensile strength.
Note that the clutch master mount is located on the inside of the firewall – so when you press the clutch pedal you are actually pushing the mount on to the firewall. These rivets only locate it and prevent it from drifting around. They are much stronger then they need to be.
Of course there is a lot more to the conversion than just the pedals and the firewall mod to hold the clutch master cylinder. But I thought you'd like to see this particular section exploded out....
We have changed out the bell housing, and are waiting for the new flywheel to arrive. Our 6-speed kit to install the Corvette transaxle is waiting on the floor next to the car, all set to go. Just need that flywheel...
Doing small projects while we wait, like modifying the shifter area to hold the manual trans shifter boot.
I will post more as it progresses.
what do think a conversion would cost if you had all the parts.?
I did not know you worked on customer cars !!!!!!
So I opened our shop to install our kits for the customers who want that about 3 years ago, and it has become an important part of our business.
This Automatic-to-manual conversion is never going to be a kit we can ship. So it will likely always be done here.
