91 bulb control location
I think (but I'm not sure) that it's in the same location in your '91 as in my '90.
I think this post about defeating the bulb control module and this post about the location of the right side air bag crash sensor might help you. The bulb controller is the box with the orange label.
![](https://lh4.googleusercontent.com/--7_i9mRtr4Q/TtGzyQ8NyYI/AAAAAAAAaZY/jObWPSQUoIQ/s800/2011-11-0095.jpg)
Archive Gatekeeper
IIRC on a '91 it's bolted to the lateral outside surface of the glovebox. Here's a pic of the connector on a '91, dangling from above the LH/EZK brains:
(Pins 7 an 10 have been pulled in order to deactivate the warning when using LED bulbs...)
![](https://webfiles.uci.edu/redwards/public/Hebert%20bulb%20control%20module%20pins%207%20and%2010%20pulled%20%232%2012-8-12.jpg)
On my '93 it's mounted like so:
![](https://webfiles.uci.edu/redwards/public/GTS%20bulb%20control%20module%20location%2011-15-14.jpg)
Archive Gatekeeper
DAMMIT! &#&$^%(@@
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
