The Other White Car - Status
#61
JOE DYER: That's an awesome car. It looks great and I'm sure it runs great.
MY PERSONAL OPINION: If you have the money to spend on it, and you don't mind, GO FOR IT. It's your car and your money. Don't let anyone tell you different.
If on the other hand you need ample justification to spend money (and possibly the wife's permission) and this doesn't qualify then DON"T DO IT. It's that simple. Only Joe knows what he did and why he made the choices he did. If you were in his shoes with his circumstances and his reasons you might just have made the same choices yourself.
As for me, Congrats to Joe and all his hard work. It looks BEAUTIFUL.
#62
In Your Face, Ace
I'm interested in your compression ratio, because a 10:1 compression engine running 11PSI on pump gas does not make 569rwhp, it is mathimatically impossible. No stones, just wondering. The engine looks beautiful!
#63
By Abby:
I'm interested in your compression ratio, because a 10:1 compression engine running 11PSI on stock gas does not make 569rwhp, it is mathimatically impossible.
For the time being, I will stand by my calcs which suggest that if the car is running 11 psi measured in the manifold, it should very well make around 569 rwhp, give or take.
However, according to the picture, if the boost measurement is taken from the blower only, there will be a pressure drop between it and intake manifold, so the actual boost the engine sees will be a little lower, probably 10 psi. 10 psi still puts it at 546 rwhp; that's still a lot of power to the rear wheels.
#64
In Your Face, Ace
To high compression ratio for the amount of pressure / fuel octane rating of pump gas.
Does it make power? yes.
Will it hold up?
Time will tell....................
For $35k he better hope it does.
Will it hold up?
#65
I have to side with Abby on the durability issues. With a couple of rebuilds, were forged pistons used the second time? I would think that an upgrade like that would be mandatory if you were rebuilding it anyway. With forged pistons I would bet it would live a long time if the A/F ratios were correct.
Of course it sounds like the shop did a great job of bolting it all together but, might be lacking in the critical area of tuning such a beast.
Best of luck to all running SC'ed 928's.
#66
#67
I'm a guy who blew up his 944 T twice. Forged pistons wont save a botched job but they certainly add stregnth and durability. Both times my turbo blew, it was on a racetrack. I fully intend to continue to run my 928 on the track 2-3 times a year. My biggest concern, and the reason I haven't yet approached Tim, is whether or not a SC'ed 928 will live on the track. Running hard on the street is no comparison. Obviously durability is compromised by pressurizing the engine. How much? I think that remains to be seen. Would I feel better if my car already had forged pistons, OH YEAH!
#68
In Your Face, Ace
The 'Tilo' Giant Killer 928 resides here in South Louisiana now and is a regular at the track. This is a stroked 6.5 litre SC'd motor. It seams to hold up fine, however this application is only running about 6psi of boost.
#69
Originally posted by marc@DEVEK in another thread over a year ago:
We have one local whipple charged twin intercooled 5.0 two valve 928 built 6 years ago...
Makes 490ish rwhp, uses a motec and has been running for years, and running hard. I have little doubt hat it could run at that rwhp for one hour straight on a brake dyno.
#70
well..I'm not one of the guys that would have thought something like that about a stroker. The stroker engine is a completely different method of making power. I would definatley consider it a less stressed engine. The SC is being put on an engine designed for lower operating stresses.
I knew when I posted that, somebody would make an attempt to compare "hard" street running with putting 250 track miles on a car in a day. There is no comparison. There is no way you can even come close to running that hard on the street.
I know a lot of guys in the 944 community that ran the exact set-up as mine on the street for years without a single problem. The problem came when run under duress on a racetrack, TWICE.
I don't think that a SC'ed car is somehow more liable to blow just based on the SC install. I know that it places more stress on the engine and that racing compounds that. I would like to see someone like Kibbort bolt one on and run for a season. THAT would be a test.
#71
Quick Carl has been tracking his supercharged '78 without issues related to stress on the engine from the supercharger. He'll be at Road America again this weekend with it.
Still waiting to hear more than just opinions on the engine not being able to handle the stress of a well done supercharger installation.
#72
Hey Joe, The engine looks amazing. Especially, since I just had my hood up and was thinking my engine looked pretty good.
I would imagine since your car is a '93 the body looks great to.
Do you have any other pictures you can post?
Congrats,
Congrats,
#73
Z,
I posted BMEP numbers for different configurtion. Do you consider this an opinion?
Supercharged stock longblocks have yet to be dyno'd every year at different ambiant temps, with different octanes, or even after 50K miles to see if there is any power degradation. Or dyno'd 10 runs in a row to see the effects of heat soak, etc. What data do you have that backs up your "reliability" statements?
No supercharged engine has yet to reach 10,000 miles!!
There has been no formal testing, no testing plan (except the one I wrote for a supercharger kit manuf over 5 years ago). Which I doubt any current kit will pass, yet stock engines as well as strokers pass! If you think a current stock block sc application has a chance, bring it on out and I will dig up the test and run it!
Dont get me wrong, I like boost....even to the point of considering building one of my own sc 928 engines to see what can be done when it is done with the intention of supercharging from the start...but stating or alleging that any 928 stock block supercharger application is equal or lower in stress to a stroker is incorrect.
HP for hp, stroker engines produce less stress than supercharged engines.
Marc
DEVEK
Marc
DEVEK
#74
In Your Face, Ace
Marc,
Is the 'Tilo' car a Devek Stroker? For some reason I was thinking it is. That car has to have a fair amount track time... I'm guessing here.
If so, that engine is holding up well!
#75
Z,
Z,
No supercharged engine has yet to reach 10,000 miles!!?
stating or alleging that any 928 stock block supercharger application is equal or lower in stress to a stroker is incorrect.!!?
