928 Forum 1978-1995
Sponsored by: 928 Specialists
I seem to be missing stabilizers???
Old Oct 26, 2014 | 07:47 PM
bureau13's Avatar
bureau13
Default I seem to be missing stabilizers???
Something looked wrong to me, like I have a piece of my rear suspension missing from both sides. Taking a look at the WSM diagram, I think it's the stabilizer. What are the ramifications of this? Is there some reason a PO might have removed them entirely?
The angle is awkward, but you can clearly see two areas that look like something should be attached.
Old Oct 26, 2014 | 07:52 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Rear drop links I believe.
Old Oct 26, 2014 | 08:10 PM
Chalkboss's Avatar
Chalkboss
Yep, drop links. How does your car handle?
Old Oct 26, 2014 | 08:42 PM
bureau13's Avatar
bureau13
Well, it's the only 928 I've ever driven, and I haven't really been pushing it, but it has felt OK.
Old Oct 26, 2014 | 08:48 PM
bureau13's Avatar
bureau13
FWIW, I've felt the car is a bit bouncy, but I was attributing that to presumably dead shocks. Since the drop links attach to the sway bar, I would guess I should be feeling more body roll. I wonder if I have the front ones?? Something to look for tomorrow, for sure.
Old Oct 26, 2014 | 09:10 PM
Richards 928's Avatar
Richards 928
Old Oct 26, 2014 | 09:29 PM
bureau13's Avatar
bureau13
Both sides missing. I have not inspected the sway bar yet. I'm thinking if I'm buying parts, it might be a good time to just get Hans' latest Ott drop links. I remember that thread from before I had my car, but for some reason wasn't initially aware that's the part I was missing.
Old Oct 26, 2014 | 09:35 PM
Richards 928
Old Oct 26, 2014 | 10:24 PM
jheis's Avatar
jheis
I've had a couple of rear drop links fail over the years.
The "O" around the bushing at the top (usually) breaks at the weld and spreads open up to a wide "C". Your PO probably removed them to keep them from bashing around rather than fixing them (they can be re-welded or replaced).
Since yours are missing, your rear anti-sway bar is disconnected, meaning that your car is going to understeer - even more than the understeer the factory designed into the suspension to save us from our selves.
James
Old Oct 26, 2014 | 11:08 PM
bureau13's Avatar
bureau13
You know, I do get a sort of clanking from the passenger side rear. I don't suppose this could be related? I'm probably not that lucky lol.
Old Oct 26, 2014 | 11:19 PM
SeanR's Avatar
SeanR
Heh, I've seen them bent at odd angles but never missing. This is going to be like a new car when you get some. Think about getting Han's new drop links, perfect time for it.
Old Oct 27, 2014 | 01:32 AM
bureau13's Avatar
bureau13
Already PM'd him :-)
