Could be $15K, could be $35K. Not enough information to tell. What transmission? What condition is the interior? The exterior? The drivetrain? Service records?
This car isnt listed on craigslist or anywhere else. I am gathering more details now. From what i understand, the car has all records, automatic trans, and very minor wear on the interior. The car is def. worth more than 5k.
Do the records include a history of flex plate release services and an accurate crank endplay measurement? At 44K miles it's likely ok, but the seller should know that an in-spec endplay number is worth several kilobucks in and of itself.
I found a 1990 One Owner 928 with 44k on the clock. Always garaged. White on tan w/sunroof. What is a realistic value for this car?
One that has had everything done already is worth ~$25-30k IMO.
A typically maintained one is going to be $20-25k (in the US, less in Canada) and need another ~$6-8k of work to be nice. I assume that it'll need quite a few minor leaks fixing, all fluids, new fuel hoses, motor mounts, timing belt (+WP) and a PKlamp (or similar). There's also the potential to need brakes and tyres. As always, an expert PPI is priceless.
