removing the fuel injector bolts
Hello. Does anyone know how to remove the fuel injector bolts off the S4 intake manifold? I bought new ones. Their is 4 of them and they hold down the fuel injector rails
They are nuts, and I use a 1/4" drive with a 10mm socket on it.
Rennlist Site Sponsor
You can usually remove stud with the "double-nut" technique. Run a nut part-way down on the stud, run a second nut down until it touches the first, then tighten the two nuts together. Turn the lower nut to remove the stud.
Wait a minute. Take some pictures of what you are doing, there is no rubber between the fuel injection rails and the intake.
Team Owner
NOTE use compressed air to blow out the sand from the injector bases prior to removing the injectors.
then use a vacuum cleaner to clean the adjacent areas.
NOTE WD40 sprayed onto the bases of the injectors will make them easier to remove apply this after compressed air
Archive Gatekeeper
Wait, stop- don't double nut anything just yet....
Is the engine in your '89 original? There some early '87 intakes that had the double-stud rubber isolators to hold the fuel rails to the intake. And the fuel rails are specific to those early intakes .
The intake pictured in the first thread below is an early '87, there are no ribs flanking the flappy bearing hole.
https://rennlist.com/forums/928-foru...-mounting.html
Another discussion:
https://rennlist.com/forums/928-foru...-s4-model.html
Here's a pic DR supplied that illustrates the fuel rail difference (same part number in PET, but NOT the same part!) Early ('87 only) on top vs. '88-95 on the bottom:
![](https://webfiles.uci.edu/redwards/public/DR%20early-top%20%20vs.%20late-lower%20S4%20fuel%20rails%204-8-14.jpg)
If your intake is an '89 and original to the car, there should just be bare studs inserted into the intake, as below. There is _zero_ reason for those studs ever to be removed from the intake.
Another discussion:
![](https://webfiles.uci.edu/redwards/public/S4%20Intake%20fuel%20rail%20mounting%20studs%2010-19-14.jpg)
To compensate for the shorter fuel rail legs, they used spacers:
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/884x663/img_3451_823e8c31ce6dc0fc7cf73aefedd61b355c1cf491.jpg)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/1024x768/img_3452_82f4796d72b3e885e90586df118ddb62b1c406f4.jpg)
(I did this to my '89 back in '08
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1024x768/img_1058_ec73abac45c668570a224c21bd4b921fe0c73e3f.jpg)
