928 Forum 1978-1995
Sponsored by: 928 Specialists
motor mounts, delrin bushings in......vibration still
Old 10-26-2014, 05:05 AM
  #31
FredR
FredR's Avatar
Malcolm,
Good to see that your instincts pointed you in the right direction even though the outcome was not as you would have hoped for. Sounds as though it might be a good time for some super bearings from Constantine.
Rgds
Fred
Old 10-26-2014, 07:29 AM
  #32
Black Sea RD
Former Vendor
Black Sea RD's Avatar
Originally Posted by the flyin' scotsman
btw..........I stuck a tape measure down the TT........didn't hit stop until 24"
Sorry to hear of the prognosis, but glad you finally found your vibration problem.
Have been watching this thread and thought this could be one of the problems. This is a classic 5-speed TT failure which results in massive vibrations.
The throw out bearing and missing bolts could have been the cause of the migrating front bearing, or other way round.
At least you now have the answer.
Cheers,
Old 10-26-2014, 08:36 AM
  #33
oups59
oups59's Avatar
Originally Posted by 69gaugeman
Your winter project has been decided!
Your MaxJax will be helpful this winter
Old 10-26-2014, 02:47 PM
  #34
the flyin' scotsman
the flyin' scotsman's Avatar
Originally Posted by Constantine
............ glad you finally found your vibration problem.
The throw out bearing and missing bolts could have been the cause of the migrating front bearing, or other way round...............
I suspect the TT front bearing migration was cause and effect of the TO brg and missing bolts issues. The vibration going through the coupler, stub shaft and clutch components were probably massive at higher rpm.
Now I have the diagnosis done I'll revise my winter project funding away from the intake and get the clutch and TT repaired.
When will you have your super bearings for sale Constantine?
Given we are on the edge of winter I do have 5 mths to gather the parts etc
Old 10-27-2014, 06:42 AM
  #35
Black Sea RD
Former Vendor
Hi Malcolm,
We are still sending out our Super Bearings, but our TT rebuilding is stalled at the moment.
Just let us know when you are ready and we'll build you up a set.
Cheers,
Old 10-27-2014, 07:55 PM
  #36
the flyin' scotsman
thank you Constantine........will be in touch PM
Old 01-10-2015, 09:06 AM
  #37
the flyin' scotsman
update: the majestic Constantine bearings are in my 928 stock and will be married to a new TT shaft from Greg Brown.
The stub shaft is also being replaced as part of the overall clutch refresh.
Thanks to the gurus who gave TT removal advice of what I refer to as the Bill Ball method that's the way its coming apart up on the MaxJax
Quick Reply: motor mounts, delrin bushings in......vibration still
