928 Forum 1978-1995
Sponsored by: 928 Specialists
Option Code M251 ??
Old Oct 6, 2014 | 11:18 PM
Bilal928S4's Avatar
Bilal928S4
Should have kept the 89 5speed!
Old Oct 7, 2014 | 10:25 AM
ROG100's Avatar
ROG100
Basic Sponsor
Be a blast, but I wonder what the revs would be at 80 mph?
As soon as I replace the two fuel pressure regulators and the damper I should be able to tell you.
Possibly - but you would have been upset when I ripped out the crap box and fitted a RogerBox.
Old Oct 7, 2014 | 11:10 AM
the flyin' scotsman's Avatar
the flyin' scotsman
holes in the cheese = holes in compression.
must have missed that calculus class!!!
Old Oct 7, 2014 | 11:24 AM
69gaugeman's Avatar
69gaugeman
Hmm, so now what we really want is an '86 Sweden/Switzerland engine and add turbos.... are there any around?
Old Oct 7, 2014 | 11:27 AM
whatudrivin's Avatar
whatudrivin
What about the noise suppressing intake tubes? Are they different from others of the same year?
Old Oct 7, 2014 | 06:06 PM
Vilhuer's Avatar
Vilhuer
Just to clarify. Low compression pistons for M21/22 was option M151. Its possible C09 and C10 cars had that engine without having option listed if it was standard based on country code.
There is separate part number for M151 piston. Actully six of them.
Some '85 MY C23 had it with code on option list while others didn't which can mean they had normal 10.4:1 CR engine. '86 MY C23 used low compression M45/46 which obviously had code M298 and M299 in those countries where that engine and cat converter was optional.
M251 gearbox is totally separate thing and is not directly linked to car having M151 engine even though some '86 MY cars had them both. Either as part of the country specific spec as as an option.
File Type: gif
Old Oct 7, 2014 | 08:37 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
The standard European automatic transmissions had a shorter gear ratio than the US version (2.36 versus 2.200).
The M251 option was a still shorter ratio for mountain road use (2.54)......and for someone that really wants a very "quick" vehicle.
Both the European and the "mountain use" transmission also came with a higher stall torque convertor....to allow the engines to get into the power range quicker. With the higher compression engines, these cars should perform quite well.
I still have a couple of these transmissions, brand new, in the factory boxes. (Both European ratio and the M251 option.)
