928 Forum 1978-1995
Sponsored by: 928 Specialists
Hanging on.....?
Old Oct 5, 2014 | 09:14 AM
9two8's Avatar
9two8
Default Hanging on.....?
Got an annoying problem when I change down from 2nd to 3rd gear that it seems reluctant to come out of gear, and that is with clutch right down to floor, any pointers appreciated as to what might cause this ?
The box was completely rebuilt a few years ago to address syncro issues so I don,t have any issues with crunching etc, just this reluctance to move from 2nd to 3rd, you really have to positively yank it back sometimes although not always.
The box is running on 75/90 oil and has,nt been changed since the box was rebuilt, which is about 11 years now, no leaks either.
Ken
80 928 S
5 Speed
UK
Old Oct 5, 2014 | 09:50 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
what was the last thing you fixed in the trans?
Old Oct 6, 2014 | 07:19 AM
9two8's Avatar
9two8
..., nothing, it hasn,t been touched ?
Ken
80 928 S
5 Speed
UK
Old Oct 6, 2014 | 08:20 AM
The Fixer's Avatar
The Fixer
Ken,
Duel clutch adjustment moved out of spec?
Clutch hydraulics OK?
Old Oct 6, 2014 | 09:03 AM
9two8's Avatar
9two8
Originally Posted by The Fixer
Ken,
Duel clutch adjustment moved out of spec? It,s a possibility I suppose need to find the post on that . If I remember rightly it was very fussy in getting that set just right.
yes, by that do you mean leaks ? if so none. A new slave was fitted well before the box overhaul.
Ken
80 928 S
5 Speed
UK
Old Oct 6, 2014 | 09:25 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
How does it shift when the engine is off?
if the issue goes away then your clutch is dragging.
If its still an issue with the engine off then ,
check the trans body, see if one of the shift rod spring holders is coming loose these would be 17 or 19 mm nut looking things on the sides of the trans
Old Oct 6, 2014 | 09:48 AM
9two8's Avatar
9two8
[QUOTE=Mrmerlin;11700700]How does it shift when the engine is off?
It,s a lot free,r in that mode, ie, doesn,t seem to hang up.
Ken
80 928 S
5 Speed
UK
Old Oct 6, 2014 | 08:41 PM
erioshi's Avatar
erioshi
Then it's most likely an issue related to the clutch. I would recommend bleeding the clutch system and also checking to make sure the clutch pedal and push-rod for the clutch master cylinder are adjusted correctly and within specifications.
Old Oct 7, 2014 | 08:05 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
check the clevis at the top of the pedal,
you may need new clevis and pin and bushings to restore full stroke of the pedal
Old Oct 7, 2014 | 10:23 AM
9two8's Avatar
9two8
Thank,s I,ll check those out and first get the clutch bled, I read a post on here some time back where newer slaves had a longer push rod fitted as the original slave had been superceded but can,t find said post , wondering if I have a problem here, ?
Ken
80 928 S
5 Speed
UK
Old Oct 8, 2014 | 05:46 AM
Fogey1's Avatar
Fogey1
Originally Posted by 9two8
... I read a post on here some time back where newer slaves had a longer push rod fitted as the original slave had been superceded but can,t find said post , wondering if I have a problem here? ...
Seems unlikely if it's worked well for years until just recently.
Now, 11 years on a fluid refill ... who knows?
