928 Forum 1978-1995
Sponsored by: 928 Specialists
What are the blanked-off tubes?
Old Sep 21, 2014 | 08:32 PM
Adk46's Avatar
Adk46
Default What are the blanked-off tubes?
What are these two tubes on either side of the air cleaner that are blanked off with light blue caps? On an '87 S4 auto. Thick-walled tubing, like for hydraulics. Just curious.
Old Sep 21, 2014 | 08:37 PM
ammonman's Avatar
ammonman
IIRC these are sample ports for emissions testing.
Mike
Old Sep 21, 2014 | 08:42 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Curt- These are test ports for exhaust gas (CO) measurements. You will never need nor use them.
From the 1987 Service Info Tech guide, page 1-14:
Old Sep 21, 2014 | 09:11 PM
Adk46's Avatar
Adk46
Ok, thanks. Upstream of the cats. No good for 007-style smoke generators, then.
Old Sep 21, 2014 | 10:30 PM
martinss's Avatar
martinss
The base of these tubes where they bolt to the exhaust pipes can rust thru causing a small exhaust leak. The top of the tube that you show can look fine. People variously replace the tube with a ball bearing, bolt or some such under the retaining nut to plug the hole under the retaining nut.
