How to check car is level
Where would you put the level to make sure that the car is level on jack stands?
This is to replace the transmission fluid. Or is eyeballing it good enough?
IIRC you open the sunroof and using the biggest carpenters level check bubble is centric in opening.......if your car has sunroof delete then use special tool 928 396 4567, Rogers has them in stock.
Alternatively one could consider changing over to the non-Rogers box much preffered by true drivers
