Fastener ID help for Air filter box?
Hi, I apologize for such a lame post, but I am in a bit of a pickle...
I am trying to remove the black plastic air filter box from my 1980 928S Euro,
and I can't ID the final fastener on the center front of the bottom half of the air filter box. It is deeply recessed, I can't get a visual on it, and to add insult I can't get PET to load on this computer due to screen resolution limitations lol.
Any ideas?
The bottom of the box also had 2 13mm bolts, but this final centrally-located fastener is in a deep recess centered at the front/nose end of the box.
Thanks in advance, as always.
Dan
Any ideas?
Dan
Mark,
Very possibly yes, the fastener does appear to run down through the rear/tail section of the plenum,
thanks, is it perhaps an Allen head bolt or a Torx bolt?
Thank you
Dan
Thank you
Dan
Archive Gatekeeper
Disclaimer- I know nothing about early cars, but PET shows two different aircleaner bottoms, 1 for 78-79 K-jet cars and 1 for 80-84 L-jet cars.
Which components look more like yours (and if it's the upper pic, then I'm confused about your '80 S having the early airbox on it..):
78-79 (with the big-*** hex bolt highlighted)
80-84:
80-84:
The fastener is situated deep in the black plastic box.... it may be better described as behind the plenum now that I think about it?
It sits in the middle front, and in this photo from the driver's side, it projects back at around a 45 degree angle?
I don't have a tool slender enough to reach in there, I may be heading to buy a 1/4 extension?
Agan, Thanks. Dan
Agan, Thanks. Dan
The Parts Whisperer
To remove the lower air cleaner you need to unscrew the 2 bolts inside and remove the long bolt that goes through the center plenum ( shown in the bottom of your picture) Thats it
Thanks gentlemen!!!!!
Much appreciated !!!!!
Dan
Dan
