K & N magic trick
#32
Been using KN filters in all my vehicles for the last 12 years. The only reason you should have any dust would be attributed to three reasons only...1. The filter was not prepared correctly (oiled) and there areas that had too little oil which allowed grit to enter the system. 2. Poor fit. 3. Problem with vehicle intake system.
There is absolutely no way that a dry filter will trap finer particulates than will a properly oiled filter. I work in the oil field industry and oiled filters are s.o.p., why do you think they use oiled "foam" filters? Unless you have just saturated the filter with oil to the point it is dripping the chances that oil is going to get sucked into the MAF is ZERO. 99.9 percent of the issues are due to improper maint. or preparation, or fit.
#33
Rennlist Site Sponsor
Several years ago, Dave Roberts ran back-to-back dyno tests with K&N and stock filters. Stock filter won. In addition, the air filter housings below the long-term K&N filters on customer cars were noticeably dirtier than those below stock filters. Dave quit selling them...
#35
Dirt will not get by a properly fitted and prepared filter.....Period. You get more air because the volume passing through the filter is greater in a K&N. How can you say that an PROPERLY oiled filter will not attract and retain more dirt???
K&N are much better for high performance cars because the allow the engine to breath. The military, NASA, oxygen/nitrogen producers, CDC, hospitals etc, all use some type of liquid based filtration system when they need pure, clean air. There must be a reason. K&N go through rigorous internal and external testing under ISO standards. As far as W.P.'s testing goes, I have not seen the testing protocols so I can not comment on it.
All I can say is that if the K&N filter was prepped correctly and the fit was airtight then there is no logical way that dust could pass through the oiled filter without sticking to it. The molecular density of the oil is to great. Your talking several layers of oiled filter agent vs paper. Give me a break!
#36
#37
EVERY TEST has proved this that everyone has publicly done.
Here, tests. With visible repeatable test definitions. One of MANY sources. K&N says they have done testing, but why would it be that their results are in direct conflict with dozens of more open, more publicly available and repeatable testing results?
It's always fun to watch blaming "bad preparation" for dusty dirty intakes all over the world.
If it's so hard to do _that_, its junk.
And that's the best spin that can be put on it.
OEM filter filters BETTER, and flows more air than _you will ever need_.
..and can never be prepared wrong, and never fits wrong.
Isn't your 928 worth that?
#38
Well Sean, I don't work for them but I do defend products that I think benefit our 928's. I have the PorKen tensioner, Constatine TT and clamp, Higher output alternator, air pump delete plus a few other improvements all of which have been maligned or championed by this forum.
You obviously love your paper filter and can't seem to get past the logic of "how stuff works". Paper is a "one dimensional" product and has its uses for some applications. If it was so good then the agencies' I mentioned that use "liquid" based filtration would not be doing so. Liquid filters naturally attract debris and are "multi" dimensional filters that are always used when high filter tolerances and air volume are required.
God#@$% you defend these crap paper filters like you work for them!!!
#40
Where is the filtration data for K/N? Rather than argue it is very simple to do a test and see what gets past the filter. If there is no data from K/N that is suspect right there. I have done particle size distribution tests with all kinds of filters and it's not rocket science.
Post a link if it's available, I would be interested to see it.
#42
FBIII: I posted a URL with significant amounts of test results.
Not sure how you missed it, but here it is again.
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
#43
I have never done any testing myself other than personal experience and working in an industry that spends millions to the right type of filtration. Clean air and lots of it is required by human and mechanical engines. Our own lungs use liquid based filtration and combustion depends on air as well.
Sure the K&N has filter in its dry state will allow more grit through, but when the oil is applied CORRECTLY and the fit is air tight dirt will be trapped. The main difference is that since the filter is multi dimensional vs one dimensional the volume is not decreased. Paper loses efficiency each day to a point that it could be sucked in depending on the intake pressure. Not good for our engines either. That's my story and I'm sticking to it.
#45
A quick search- Here is what they publish:
http://www.knfilters.com/faq.htm#21
Interesting to see how that stacks up to air but I don't have the time to delve into it right now.
