Is this crank scoring OK?
Removed oil pan and am admiring the crank from below.
I read some posts here saying that there is scoring visible simply from machining at factory. Is that what I'm seeing here in first photo or is something more sinister happening?
The pan was completely free of any metal particles, and crank end play was in spec when i checked last year.
Adrian
Adrian
Please can you or anyone in the know indicate with photo where I should look, or just help me navigate in terms of how many rods/pistons along from rear towards front?
Thanks. I looked hard at that write-up originally but struggled to get my bearings (no pun intended) from the photos.
But I've had another look at the WSM 13-4 and I think I should be looking for lip of bearing either side of the central rib of the lower crankcase?
If that's correct then I'll post a photo later.
Adrian
Adrian
Here are what I am pretty sure are the aft and fore sides of the thrust bearing.
Still seems plenty of meet on it!
It can look as if it's going thinner, but it's just the oil drops that creates that effect.
I'm probably being paranoid but would like to know if it's ok to check end play on car in current state - engine is raised and supported at front, and starter motor is out. Is it ok to pry things in that situation?
