O2 sensor plug repair
Chronic Tool Dropper
Also, a question for the experts in light of Carlos' diagrams. When I took apart the green wire white connector, I found that the core wire terminated to the metal bullet, but the shielding wire terminated to nothing within the white connector. If this shielding wire is connected to common grounds, wouldn't this leave an open ground?
Josh
Josh
Looking at the later cars with heated sensors, the wiring for the heater (power supplied by the fuel pump relay) has all three conductors unshielded and untwisted. Whatever noise protection was imagined, it was not a problem in the later cars.
And a FWIW on soldering the sensor cable -- I solder spliced the sensor and heater wires a few times now with sensor replacement, and it's working fine. The sensor wire itself is small, and has thin kynar or similar insulation on the stranded conductor. Hard to believe that the sensor actually expects to see a reference oxygen sample drawn through that wire and insulation. There is nothing to cause such a flow that I can see, even if the wire were snaked through a straw with an air gap around it. My casual experience.
80-94 show a shielded O2 signal wire (with 83-94 showing the heated sensors). That shielding is always only shown on the signal wire and always only for that part of the signal wire going from the connector (inside the car) to the computer. However, the part of the signal wire coming in from the O2 sensor (outside of the car), coming in through the grommet in the floor/tunnel, and ending at the connector (inside of the car) is never shown shielded.
I don’t have an electronics background, so I may not be clear in my description. Below is a wiring diagram for the 1994 MY. The green marking follows the shielded wire to pin 24 on the computer with pin 5 (shown beside it) being used to ground the shielding.
