Fuel tank capacity ?
Can't say I've tried that but you will have 3-4 gallons left for the empty warning light to trigger.
Just wondering if I,m expecting too much from the gauge with relativley little gas in there, I asked if they had disturbed the sender from the tank, but they had,nt. Obvious answer is to fill the tank, but don,t want to do that incase I have to remove the sender, although as previously mentioned, there does seem to be a slight bit of movement on the needle while at the empty section of the gauge. So basically, How much gas in the tank does it take to register at the gauge ?
Ken
80 928 S
5 Speed
UK
There is the reserve after the light comes on. On my 90S4 I once ran it until the range showed -35 miles. Just could not find a gas station. It made it under it's own power. Since then have not pushed it below +30 miles on the range.
According to the owner's manual on my 90GT, the the low fuel light comes on when the tank has 12L or less (3.2 gallons). So I would think you need close to that to make the needle register anything. The tank capacity is the same on all years, just the sender is different on 89-up.
Total tank capacity is 86L (23 gallons) which includes the reserves mentioned above.
Cheers!
Carl
Cheers!
Carl
FWIW the 84 tank capacity I believe is listed as 19 gallons. I'm pretty sure the last time I put fuel in it when the fuel warning light came on, I pulled into a gas station pretty quickly and put in about 17.5 gallons. So don't count on 3-4 gallons left.
Rennlist Site Sponsor
"FWIW the 84 tank capacity I believe is listed as 19 gallons"
Nope. As FLYVMO said, all tanks are the same. The '85 spec book says fuel tank capacity is approx 86 liters, which is 22.7 US gallons, including 8 liters reserve, which is 2.27 US gallons.
They are all listed as 23 gallons. Link to 1984 owner's manual: https://docs.google.com/file/d/0BzC7...it?hl=en&pli=1
If the tank only takes 17-ish gallons there is probably a venting/kinked line issue. I've put 20 gallons in at the pump plenty of times.
EDIT: Wally types faster than me![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Cheers!
Carl
Cheers!
Carl
The gas tank looks like a teapot. You fill it through the spout. If the vent line from the top of the tank main body is pinched shut it traps a big air bubble in the body of the teapot while the spout fills up and kicks of the filler nozzle. That air bubble must be around 5 gallons
The vent line is supposed to pass through a hole in the rear frame rail and end up near the top of the spout
Thanks Wally. I could have sworn it was 19. Well that makes sense then. My light came on at just over 17 gallons. That i know for sure.
Looks like I,ll just have to put around 4 gallons in the tank, and see if the needle registers, it was working fine before the fuel system was cleaned out and they did,nt touch the sender, ?
Ken
80 928 S
5 Speed
UK
