928 Forum 1978-1995
Sponsored by: 928 Specialists
Noise coming from passengers side valve cover
Old 08-02-2014, 08:41 PM
  #76
1989porsche928
1989porsche928's Avatar
Just to give you an update. I have the Timing Tool. I thought I was doing a good job then I put the engine back to TDC. The passengers side was right correct. The tool lines up, the notches lines up. The driver's side is off many teeth to the right. I asked around someone one said to turn it back to 45 degrees slowly and start over. What do you all think?
Old 08-02-2014, 08:53 PM
  #77
SeanR
SeanR's Avatar
If the timing marks on the camshafts are off so much in correlation to what the crank shaft says, there is a good chance you have tapped some valves.
I just put this thread and your PM together and if what you are saying is correct, you have got to get everything lined up at TDC and ensure things are right. Crank at TDC, both cams at TDC. If those do not line up you've got some major issues. 18 teeth off on the drivers (left) side is going to result in tapped valves and some major engine work.
Take some pictures as to what your cams and crank show when you put them to TDC.
Old 08-02-2014, 09:03 PM
  #78
1989porsche928
sean right now the belt is off and the engine is at TDC. The passengers side cam gears notch is lines up with the notch for the cover. The driver's side is off.
Old 08-02-2014, 09:15 PM
  #79
SeanR
SeanR's Avatar
Take the Porken timing tool off, it's of no use when the belt is not on the car.
Put the belt on the crank, then oil pump gear and move the drivers (left) cam gear in to position and put the belt on there. Using an assistant or ensuring the cam gear stays in place on the drivers cam gear, run the belt under the water pump pulley and start to move the passenger cam gear (right) in to position and then put the belt on.
(this can be a pain in the *** to get right so take your time, and don't get pissed when you have it a tooth off, do it until you are on it right)
I don't know what belt tension system you are using, but at this point you should be able to either pull the pin on the PKTensioner or start to tension the belt using the factory tensioner.
  #80
SeanR
SeanR's Avatar
Where are you located? If someone is close, it looks like you could use some assistance.
Old 08-02-2014, 09:25 PM
  #81
1989porsche928
im in new windsor, ny.
Old 08-03-2014, 10:04 AM
  #82
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,559 Likes on 1,437 Posts
Please , best advice, have another 928 savvy person to inspect your work.
Old 08-03-2014, 07:54 PM
  #83
Bilal928S4
Bilal928S4's Avatar
I am a couple of hours away. If you are REALLY stuck, I can make the trip.
Old 08-04-2014, 01:19 PM
  #84
Chalkboss
Chalkboss's Avatar
Any updates?
Old 08-04-2014, 08:05 PM
  #85
1989porsche928
thanks for offering help. I had one of my friends come over. The timing is on. I just have to double check everything, put all the covers back on, double check everything and then start the car. I will be on work on it this weekend. I'll let you guys know how it goes.
Old 08-06-2014, 12:27 AM
  #86
1989porsche928
I am considering making a new hall sensor bracket or buying an '87 (the one I saw did not have the connector holder). I think what might have happened is my bracket got bumped when installing the valve cover. It could have set the hall sensor to be tilted a few degrees. This could have been enough to make it crash into the timing rotor. If you look at an '89 bracket it has a holder for the connector on it. Any opinions? I also really don't feel comfortable with the way the wires have the U-Shaped rubber piece that is supposed to seal it. It just does not seem like a good design to me.
Old 08-08-2014, 10:10 PM
  #87
1989porsche928
Alright after reviewing some post I decided to install the old hall sensor and the old bracket. I carefully placed it on. I took a picture of it installed. Please tell me if you think the small gap on the non bolted end is safe.
Old 08-08-2014, 10:30 PM
  #88
SeanR
SeanR's Avatar
That looks normal to me.
Old 08-09-2014, 08:55 PM
  #89
1989porsche928
I am in the process of putting it back together can someone tell me were this bolt might belong to?
The head of the bolt reads LOBO 8.8
Old 08-09-2014, 09:29 PM
  #90
SeanR
SeanR's Avatar
Just for an FYI on something similar to this.
I just got done diagnosing a car with similar issues today, and both.........repeat BOTH........cam gears were held on by bolts that were finger tight.
Quick Reply: Noise coming from passengers side valve cover
