Interior lights
So im having this issue where my interior lights only come on when my rear hatch is open, both driver and passenger doors opened wont turn them on like they used to. I've checked the door contact switches and they are both good. any idea where i should be looking?
Clean the area where the contact switches contact the body, also check the ground wire inside of it to be sure it isn't corroded. If it is, trim it back and reconnect the pin switch.
Team Owner
add some deoxit to the pins and the seating surfaces of all 3 switches
