I screwed up once again
In my exuberance about finally getting pictures of our part of the world on my threads, I completely forgot that I was still logged onto another persons thread. I apologize for that and will present my situation once again.
Firstly, the signature picture is one of the Snowy Range with Medicine Bow peak just off to the left; elevation slightly over 12,000 feet. The car is parked at an elevation of a little less than 11,000 feet which is the elevation of Snowy Range pass.
The other picture is just to the south of Lake Marie, about a mile from the signature picture.
Now for the technical aspect:
You will note a black line across the top of the signature picture. Can anyone say how to get rid of it. Also, how about making the picture a bit larger.
Hopefully this thread won't screw up someone else's thread. Again, profound apologies.
Well Barney, you finally succeeded.
The little black line can't be eradicated - it is a 'factory install' for the signature line.
You can hit Return and drop the picture down a bit.
I added two additional lines in my signature to have the 'factory' line fit in better.
Great images by the way.
Add: If you drop the picture down a bit, you can put your car data above the picture.
