Ground Point MPIII
Thanks to Jim C and the Sharktuner I discovered the AFRs for my two cylinder banks differed significantly. At this point my best guess is an electrical issue so I started looking for the standards: cracked wires, bad connections corrosion, etc, etc. I check out the MPIII ground point, just beneath the jump start post and no wires were attached to it. The bolt was there but NO wires.
Scrounged around and found them (there are 2 brown wires going into a single ring connector) and the distributor ground strap bolted to the coil mounting bracket.
This might be an OK ground but I am going to move the brown wires back to MPIII position. What is the correct mounting point for the distributor wire?
Yes Stan, I am using DeOxIt on every connection.
Thanks, Ralph
Thanks, Ralph
