Tensioning Roller Bracket Removal Help
Hi. I've almost got the cambelt off but have run into a small problem. I tried to remove the roller bracket with the 4mm allen key bolt and the bolt just rounded off immediately. Any suggestions for getting this out?
Drill it off
Inventor
Undo both of the other bolts then tap the bracket upwards/CCW?
Chronic Tool Dropper
What Ken said, then what Aryan said. If that doesn't work, do what Sean said.
Community support at its finest!
