928 Forum 1978-1995
Sponsored by: 928 Specialists
Hub Cover Removal
Old 05-28-2014, 12:51 AM
MainePorsche
MainePorsche's Avatar
Thanks MJ.
Old 05-28-2014, 12:52 AM
jon928se
jon928se's Avatar
Originally Posted by j.kenzie@sbcglobal.net
I used an exhaust clamp, and a claw hammer to lever off the lugs studs. It is a PITA, but worked OK. I think it was a 1-7/8' clamp.
Good luck,
Dave
I initially used an exhaust clamp 50mm IIRC and lever with a pry bar. When this kept pulling off on a stubborn hub cap I then improved by buying another exhaust clamp, discarded the U Bolts from both, then used both of the C shaped pieces clamped together with two long bolts.
Old 05-28-2014, 01:02 AM
MainePorsche
Two exhaust clamps - great minds think alike.
I like the idea of the long bolts and the two clamps together.
Old 05-28-2014, 01:13 AM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Originally Posted by MainePorsche
How'd you manage that ? I tried something along that line and found I had no room to maneuver.
Persistence and more than gentle tapping. Work around the cap by turning the rotor. The piece of scrap oak flooring I use is tough enough to handle the job pretty easily. I just don't like leaving character marks on the parts, and the exhaust clamps will do that for you.
Old 05-28-2014, 01:17 AM
MainePorsche
Originally Posted by dr bob
...I just don't like leaving character marks on the parts, and the exhaust clamps will do that for you.
Hmmm...
Old 05-28-2014, 01:31 AM
James Bailey
James Bailey's Avatar
rest assured that NOTHING you will do levering on it is anything close to the forces encountered on a high g corner......I just tap lightly with a hammer and walk it out but I do leave marks It really wants to come out ! Also worth mentioning that if the bearings need to be tightened they probably need to be changed and inspect the alloy hub as well as I have pushed the bearing race into the race with all my track time.....so serious loads involved.
Old 05-28-2014, 01:39 AM
MainePorsche
Thanks Jim.
Now is just a quick inspection. I'm not having a known issue with them. I plan on new rotors soon, and when I do this I plan on doing the whole refurbish of the wheels.
Old 05-28-2014, 01:44 AM
granprixweiss928
granprixweiss928's Avatar
I just did it with a 2" exhaust clamp ($2) and a crow bar. With a hammer I could not get enough leverage. And take off the rotor first to get a better angle, put the butt of the crow bar on the hub between the studs.
Old 05-28-2014, 01:48 AM
MainePorsche
Thanks granprix.
I followed your job - looks great - nice work.
Old 05-28-2014, 06:56 AM
M. Requin
M. Requin's Avatar
I use a short section of scrap hardwood flooring, and a hammer. Leaves no marks on the cap, vs the factory tool or the muffler-clamp methods.
Works just fine. Small taps, patience.
Old 05-28-2014, 10:43 PM
jpitman2
jpitman2's Avatar
I get a screwdriver about 5/16" dia shaft , place it in the groove between the hub and the cap, tap the side of the shaft, round and round, and it eases out with little effort...
jp 83 Euro S AT 55k
Old 05-28-2014, 10:49 PM
MainePorsche
jp 83 Euro S AT 55k
Really.
I wouldn't have thought it, but I will try it.
Thanks.
Old 05-29-2014, 12:29 AM
FBIII
FBIII's Avatar
I have had good success using a ball joint pickle fork and a hammer. The fork has a slight angle that gives you a better approach angle. Using the fork allows you to tap the cover on two points at a time that seems to help.
Old 05-29-2014, 12:37 AM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,709 Likes on 1,312 Posts
I use a 9165 and a Harbor Freight slide hammer, works in about 5 seconds.
I'm headed to the post office tomorrow with some other 928 parts, I could toss it in the mail to you if you like.
I like the sound of the round screwdriver shaft in the groove, that's crafty.
Old 05-29-2014, 12:53 AM
upstate bob
upstate bob's Avatar
at first ole Bob wondered what hub yer talkin' about... oooohkay, that one. I'm a stickler for greasing bearings and went there when I first bought mine. PO had done a crappy job of setting the clearance too. I have new bearings in a box that I really should install. I welded an attachment on a muffler clamp that works well with a small slide hammer.
Quick Reply: Hub Cover Removal
