928 Forum 1978-1995
Sponsored by: 928 Specialists
Completed brakes overhaul
Old 05-25-2014, 02:03 AM
granprixweiss928
granprixweiss928's Avatar
Default Completed brakes overhaul
I completed my overhaul/rebuild/refresh of my brakes and related suspension components.
Heres what I did
replated the F/R calipers, backing plates, suspension hardware, rotors
installed new seals in the caliper kits
painted, cleaned and repacked Axles
replaced rear wheel bearings
painted rear lower control arm
installed stainless Goodridge brake lines
inspected front bearings
brake fluid flush
before:
after:
before:
after:
Old 05-25-2014, 02:45 AM
crushingday
crushingday's Avatar
Looks great. Might you have other pics of the car and interior. I wrecked my '87 944S/968 conversion this winter and Have been reading all I can about the 928. I think I probably am now more educated on the 928 than I was in to 20 years of owning my 944. I may be getting an OB soon. Infact a white '78. The seller says the ball joints have NOT been done. Might you have any idea what parts cost and hours labor might be involved to complete this all important maintenance? Any "While you're at it" suggestions would be helpful too.
Old 05-25-2014, 03:10 AM
granprixweiss928
factory lower ball joints were aluminum and should be replaced asap. My car had them with 56K on them...
Old 05-25-2014, 04:36 AM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
That looks so nice - will you still drive it, or put it into a museum?
Old 05-25-2014, 04:51 AM
Ad0911
Ad0911's Avatar
I'mso jealous! The plating company I always use refused to do the calipers because according to them the plating won' stick on Porsche calipers, so I painted them.
Old 05-25-2014, 08:25 AM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,325 Likes on 501 Posts
Beautiful job.
Congrats.
Old 05-25-2014, 08:37 AM
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,235 Likes on 755 Posts
I still regret not treating the hats on zimmermans I installed back 10 years ago..... Some day when all the other mechanical backlog on the farm is up to date (for the next 5 minutes) I will pull the rotors and get the hats painted. Nice job. Brakes on these cars are a fun and easy science project, for sure!
Old 05-25-2014, 08:50 AM
AirtekHVAC
AirtekHVAC's Avatar
Man, looks great! I just sprayed mine, all ghetto like.....was happy with it until I saw yours.....now I am embarrassed.
Love the white.....I want a white one with cork interior......one day.....
Old 05-25-2014, 08:52 AM
Leon Speed
Leon Speed's Avatar
Replated the entire rotor?
Old 05-25-2014, 11:39 AM
granprixweiss928
yes. on the pad surfaces the coating will wear off with braking. the coating is thin. Might need to replace my pads soon tho.
the coating I had done was clear zinc. then I painted in clear the hats to make the finish last longer. the calipers and backing plates also.
Old 05-25-2014, 09:40 PM
Five-8
Five-8's Avatar
All i can say is ...WOW!
Cheers,
Old 05-25-2014, 11:01 PM
The Fixer
The Fixer's Avatar
Gorgeous,
I bet you're satisfied with that.
Old 05-26-2014, 12:33 AM
MjRocket
MjRocket's Avatar
Now those are to damn nice to dirty up with silly driving!
All joking aside those look fantastic!
Old 05-26-2014, 03:01 AM
Chalkboss
Chalkboss's Avatar
Fine work Mark! Job well done.
Old 05-27-2014, 01:45 AM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Steel ones, no probs..alum ones..alodine them first.
Quick Reply: Completed brakes overhaul
