928 Forum 1978-1995
Sponsored by: 928 Specialists
Oil cooling options.
Old 05-23-2014, 05:28 PM
  #46
bwoyat
bwoyat's Avatar
Default Liner pics
It's not pretty but it's functional! Just use an angle grinder and bend the pieces with a heat gun...
Old 05-26-2014, 01:26 AM
  #47
Ducman82
Ducman82's Avatar
sucks air in or pushes out in to wheel well?
Old 05-26-2014, 12:22 PM
  #48
bwoyat
bwoyat's Avatar
The fan pushes the air out. Plus I suspect that the wheel rotation would create a suction effect? Not sure though cause I don't think anyone has commented on airflow patterns in a wheel well...
Old 05-26-2014, 12:29 PM
  #49
Lizard928
Lizard928's Avatar
Ducman has the cooler correct.
It is wired in with power taken from the ABS power line.
The hoses are 5/8" ID with a 250 psi pressure rating.
The install is pretty simple actually.
Old 05-27-2014, 06:51 AM
  #50
UpFixenDerPorsche
UpFixenDerPorsche's Avatar
Old 05-27-2014, 06:59 AM
  #51
UpFixenDerPorsche
Originally Posted by ptuomov
UpFixenDerPorsche:
I think a clean heat exchanger is great, both inside and outside.
However, I don't think the factory shroud is that bad, and I think it's better than no shroud. The holes needed to match the flow rate thru the heat exchanger are surprising small, and I think the shroud makes some effort to keep large debris out. I am sure the shroud can be improved, but my experience is that - as far as the air flow planning goes - factory engineers were no dummies even in the 1980's.
Hi Ptuomov.
Agreed re deflecting debris. And I agree that '80's factory engineers were no dummies, same as 70's, '60's, ...... 30's etc.
Problem was cost panicked management (Projekt 928 in 90's) directing what will be.
As it happens, Porsche did acknowledge shortcomings re this area.
Quick Reply: Oil cooling options.
