Does this have a part number?
Received 1,609 Likes
What's wrong with this picture. One of these is not like the other.
![](http://members.rennlist.org/worf928/100_4479sa.JPG)
![](http://members.rennlist.org/worf928/100_4480sa.jpg)
This 190k-mile '87 is missing the right-side upper radiator mount. Looks like the spot welds gave up.
I've looked through PET several times, but haven't run across anything that looks right.
Does anyone know if the mount points have a part number? Failing that, anyone have a body in white about to go to the crusher? I've got a freshly-resealed radiator for this one. All dressed-up and no place to mount.
No part number - the weld failed - had the same issue on my 93 GTS - I drilled out the welds and used pop rivets to attach it.
I have one if you need one.
Archive Gatekeeper
The PET sheet it _should_ be on is 801-05 but nothing on that sheet matches up.
Lateral edge of the front clip, for posterity:
![](https://webfiles.uci.edu/redwards/public/Hebert%20headlight%20bump%20stop%209-28-11.jpg)
(Kinda) medial edge of the front clip:
![](https://webfiles.uci.edu/redwards/public/Hebert%20medial%20side%20of%20right%20front%20clip%20showing%20brackets%20and%20clips%206-5-11.jpg)
Closeup:
Closeup:
![](https://webfiles.uci.edu/redwards/public/Hebert%20RF%20inner%20fender%20liner%20showing%20radiator%20mount%20bracket%206-5-11.jpg)
Archive Gatekeeper
Yep, that's the Hebermobile.
