High Idle when warm on GT
Would be nice, but for some reason, Porsche decided to make the Cdn display a metric only one (at least for the 89 model year...not 100% sure on 90 and up)...no way to switch back and forth.. Not sure why as the German version can switch back and forth????
Solved
Issue solved. The problem was, when I re installed the Plastic shroud that holds the Air-intake filter, the small tube that connects "it" to the air-pump (passenger side) was not seated correctly (at all) ...once i fixed that...it solved the high idle.
