928 Forum 1978-1995
Sponsored by: 928 Specialists
928srus windscreen trim is awesome!
Old 01-17-2019, 10:47 AM
  #46
Adamant1971
Adamant1971's Avatar
Received 1,128 Likes on 529 Posts
Originally Posted by ROG100
I stopped selling them because of potential fitting issues. The seal is soft rubber and the same shore hardness as the original GTS seal. The cross section of the seal is an identical copy of the Porsche 91 to 95 seal. The seal requires careful installation on pre 91 cars due to the gap being different including the trim clips.
The trim needs to be a tight fit for obvious reasons. This requires the trim to be pushed into the slot. In doing so too much pressure can be exerted and the older more brittle glass can crack. It did so in a couple of installations. Because of this I withdrew the seals from the market.
Probably sold about 50 sets and have them fitted to 3 of my own cars. Better to be prudent than see expensive windshields being broken.
Yep, I had to trim mine down on the driver side towards the top. I could totally see how someone could damage something by trying to force it. To bad cause I think it was a great product, perhaps they could be made with a softer material to allow more compression? (Assuming you probably already investigated that)
Old 01-17-2019, 01:49 PM
  #47
SeanR
SeanR's Avatar
I installed several of them and it takes some care to cut them down, fit, re-trim and do it correctly. One day I was doing one and a buddy was doing his (first timer) and his windshield cracked after the stuff was installed, an original one at that.. He forced it in instead of gently pushing it in place. I was going to fit them to my car but the new windshield install didn't leave enough room for me to do so. Each one is different, especially if a previous windshield was put in, in the past. Was a good product but I agreed with Roger that pulling it from the shelves was the best way to eliminate issues with people installing them wrong.
Old 01-17-2019, 01:58 PM
  #48
Tony
Tony's Avatar
Mine cracked also...not sure when after the installation but...if i didn't point it out you wouldn't see it. Its a shallow 1 1/2" arc in the black trimmed area on the passenger side, half way up.
Definitively some sort of pressure point. This is a replacement windshield and the rubber trim was exceptionally tight to put it. my guess is the sealant/adhesive application was too thick on the replacement windshield . I almost gave up on it, but with some soap it went in smoothly. no other issues now in a couple of years. It did cut down some wind noise.
Old 01-17-2019, 02:13 PM
  #49
ALKada
ALKada's Avatar
A little trimming and some soap on install and mine went in fine and are still there. No cracked glass. Now when I go to replace the windshield due to age/pitting, I’ll have to pull them out.
Old 01-17-2019, 07:13 PM
  #50
merchauser
merchauser's Avatar
Originally Posted by The Forgotten On
Sadly Roger stopped selling the strips when a few people's windshields cracked.
I recommend getting the Porsche sealing strips and GTS trim. The trim is cheap, the seals... Not so much.
I don't see any reference in PET to different sealing strips and trim for GTS. what is the difference and benefit?
Old 01-17-2019, 07:24 PM
  #51
ROG100
Basic Sponsor
ROG100's Avatar
Fitted from 91 to 95 ---- PET Illustration 810-000 item #36
GTS Windshield Rubber Side Seal Left 928 559 519 00 70C
GTS Windshield Rubber Side Seal Right 928 559 520 00 70C
All 87 to 90 have the correct trim already. Earlier cars may need the later trim.
Old 01-23-2019, 06:05 PM
  #52
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
I have 1 very nice used pair of OEM originals
Old 01-24-2019, 11:23 AM
  #53
bureau13
bureau13's Avatar
PM incoming...
Quick Reply: 928srus windscreen trim is awesome!
