928 Forum 1978-1995
Sponsored by: 928 Specialists
Window Trims
Old Aug 2, 2003 | 10:12 AM
CT928's Avatar
CT928
Question Window Trims
Like most other 928's I've seen, the black trims around the windows in my car have worn through to silver. I'm going to get them powder coated black again.
Anyone got any thoughts on this?
Old Aug 2, 2003 | 12:47 PM
Scott G's Avatar
Scott G
CT,
Try this thread. No mention of powder coat though, only paint.
Old Aug 2, 2003 | 01:27 PM
User 4221's Avatar
User 4221
A good friend of mine had his 911 trim powercoated. It looks great and is very durable.
That's the route I'm taking when my trim comes due.
Scott
Old Aug 2, 2003 | 04:49 PM
Oscar R's Avatar
Oscar R
CT, Jaeger engineering seems to have these trim pieces for sale. If I recall correctly, they're priced at ~ 19 bucks. Hope this helps.
Old Aug 3, 2003 | 09:16 AM
tekwaldo's Avatar
tekwaldo
Tell the powder coater to use a semi-gloss black,15-25% I t will look like the anodized finish. Be careful taking them off, I ruined two of my pcs. that way.
Old Aug 3, 2003 | 09:30 AM
CT928's Avatar
CT928
Thanks guys,
I gave them to the powder coaters last night.
I was given the option of gloss or matt black. I went for matt.
I've just had a call to tell me they are ready.
Only problems was that they couldn't do the little clips. So I reckon to spray them matt black because they are onlt small.
Old Aug 3, 2003 | 09:37 AM
CT928's Avatar
CT928
Also FYI
Total Cost was US$ 80 or so.
Old Aug 3, 2003 | 10:26 AM
ajd0002's Avatar
ajd0002
CT, did you do side and rear window moldings? I have the same problem with fading so will be tackling soon. How difficult were the moldings to remove? Any special tools/tips?
Tks
Old Aug 3, 2003 | 01:07 PM
tekwaldo's Avatar
tekwaldo
The hatch moldings are easy. When you do the rear qtr. windows you must take the whole window and rubber off. You must also put it back the same way, thats the only way it works. Its very easy if you have a window rope and dish washing detergent.
Old Aug 3, 2003 | 07:14 PM
CT928's Avatar
CT928
Ajd,
I got all of the trims off with the careful use of a wide paint scraper and a screw driver. You have to be very gentle.
I haven't removed the rear quarter windows though.
Waldo, I didn' have to take my windows out. Are they not bonded in?
Old Aug 3, 2003 | 07:33 PM
User 4221's Avatar
User 4221
You can remove the rear quarter window trim without having to remove the glass.
I was able to re-install the trim into the old window seals but it is not recommended. According to the workshop manuals, to install the trim, you have to install the assembly as one unit..... Glass, rubber seal and trim.
Check the note above on using a rope and dish soap. It can be a real PITA.... You might think about buying new seals if you take them out.
HTH,
Scott
Old Aug 3, 2003 | 09:33 PM
GT Jackson's Avatar
GT Jackson
I've installed rear window trim with the glass in using "Mr. Bubbley' as a lubricate. That's the 50 cent bottle of kids bubble wand liquid, works great.
