928 Forum 1978-1995
Sponsored by: 928 Specialists
Headlights, Speedo dead - ign switch to blame?
Old 04-26-2014 | 08:13 PM
rlich8's Avatar
rlich8
Default Headlights, Speedo dead - ign switch to blame?
Headlight switch has absolutely no effect. It worked when I bought my car back in December.
Speedo also is dead (but the odometer and tripmeter work just fine).
I remember reading about a possible faulty ignition switch to blame for these issues. Can any of you speak to this?
Any ideas before I start replacing parts?
Old 04-26-2014 | 08:20 PM
HaydenM1974's Avatar
HaydenM1974
Do the parking lights come on at all? I would think that they would work regardless of the ignition switch as you don't need a key to turn them on.
Old 04-26-2014 | 08:50 PM
rlich8's Avatar
rlich8
Now I'll have to check on the parking lights. I think they work.
Old 04-26-2014 | 09:05 PM
Alan's Avatar
Alan
Electron Wrangler
Do the brake lights work? Have you checked the fuses e.g. fuse 19 for the headlight motor...?
Alan
Old 04-26-2014 | 09:11 PM
rlich8's Avatar
rlich8
Brake lights, indicators work (although probably irrelevant to this issue). Fuse is OK. Grounds clean. Double-checking on the parking lights. I'm beginning to think relay.
Old 04-27-2014 | 06:24 AM
jheis's Avatar
jheis
Relay, relay, relay.
On my '82, all the instruments went dead - with the exception of the speedo which would bounce in time with the turn signals. Usually would clear itself within a few miles. It finally got to the point where it wouldn't clear and I was afraid to drive it because I couldn't remember how much gas was in the tank.
Tried shooting each relay with an IR meter - no help. So I started pulling relays, one by one. When I pulled the flasher relay, my instruments came back. Replaced the flasher relay and all is good.
No idea why a bad flasher would take out all the instruments.
Old 04-27-2014 | 11:49 AM
rlich8's Avatar
rlich8
All of my other gauges work just fine. It is literally just the speedo that is dead.
I wonder if the flasher relay is one I can find locally.
Old 04-27-2014 | 02:27 PM
rlich8's Avatar
rlich8
Wow, I'm really slow... I double checked the fuse panel again for #19 and ITS GONE. I deserve the idiot king award today. I was testing something a while back and never put it back. Silly silly me!!!
Old 04-27-2014 | 02:54 PM
Alan's Avatar
Alan
Electron Wrangler
That will certainly do it ... Always start with the easy things - it's nice when there isn't really anything to fix...
Sometimes you get lucky - savor it for now!
Alan
Quick Reply: Headlights, Speedo dead - ign switch to blame?
