Our V 12 6-Speed Project Starts
#107
Last piece of clutch mystery....
With Flywheel, clutch disc, and pressure plate bolted up, the PP tines are 2.87" from the bellhousing/TT mating plane..... So the T56 throwout bearing should also work with the factory Porsche Clutch MC....another win
http://i94.photobucket.com/albums/l9...earingDims.jpg
#108
![Amazon.com: [QTY 2] DANGER DO NOT TOUCH NOT ONLY WILL THIS KILL YOU, IT WILL HURT THE WHOLE TIME YOU ARE DYING - VINYL STICKERS DECALS [4 X 3 INCH]: Office Products](https://rennlist.com/forums/images/misc/amazon_icon.gif)
http://www.ebay.com.au/itm/Danger-Do...item1e8ab24c8b
#109
The first pic is the ACT clutch mounted up, good for 500' lbs
The second pic is 55 mm Honda throttle bodies with tps, map, iac. (very small and complete throttle bodies for cheap.
I would like to say thank you to my crazed Sicilian wife Debbie for all the help on this project,
#111
Archive Gatekeeper
Madmen. Madmen, all of you. I love it.
#112
Team Owner
nice work please keep feeding the pictures
#117
Howdy Fellers. Made some progress today and here are a few pics. V 12 is installed, motor mounts lined up perfectly. 3/4" clearance between the oil pan and the cross member.
#119
Damn Jeff, there is way more room in there than I expected. Can't wait to see this in person.
#120
Howdy Fellers! Here are a few more pics as I install the ancillary components. Next step is to build the exhaust system.
