Cracked Flexplate
Cracked Flexplate
Hey all,
While checking the crankshaft end play I found that the flex plate is cracked. Do I have to remove the entire TT to change it, or can I just remove the bolts where the shaft is attached and replace. 87 S4 with 126k on the odometer.
You should be able to get away with simply pushing the collar back and removing the bolts on the flywheel.
Yeah, what he said. As long as you can get all the bolts loose you are good to go. They should come right out.
