Are the chips in the 88 EZ typically soldered?
Installing a set of PorKen chips.
Open up the EZ and the original chip is soldered in place. Is this typical for the 88? I thought it was just a push fit.
Not that chip!
It's under that cover above the chip in the photo above!
The cover is held in place on the sides of the EPROM.
Use a small flat blade screwdriver in the slots provided on top of the cover release the tabs.
Well my eyesight isn't as good as it was, but I am sure the legs are soldered. I tried to gently pry from side to side, but I have just succeeded in straightening the legs. I've also attached a pic of the back
