Tire pressure question
For Street/Highway on street tires 36F and 34R cold. The highest to not get center tread wear.
For Autocross 28F&R they heat up to 34psi. Settled on 28 because 34 hot was the most I could run without the center of the tread blistering and 28 is what they cool down to.
If you work on the principle that each corner carries 400kg, you can use the max load at max pressure proportionately to give you an idea of the range of possibilities.
You rear tire pressure looks reasonable given the size -the front ought to be proportionately higher I would suggest- probably about 35 psig but of course it also depends on type of useage.
Regards
Fred
Regards
Fred
Been selling Twinkies on Ebay,
have some extra cash right now.
You can see in my photo below some white shoe polish applied to the shoulder of the tires to monitor tread roll over. 36/34 is what always worked best for me.
