Flocked dash project
The dash was in similar condition. Here are pics of the pod and dash after application of the mat and resin. Following this was the usual multiple application of lightweight filler and resin and sanding to get the surfaces ready for flocking:
The defroster vent holes on the dash were the hardest part of the job. I took multiple applications of material and filing/sanding to fair those holes so they looked right, and I'm still not entirely satisfied.
Then the fun, i.e. flocking began. I used a hand pump to spray the flock (I got all the materials from DonJer Products Co., and used their Suede-Tex for this job. No affiliation etc.). Spraying is messy, and you use many times more product per square inch than what actually adheres. This means you recover and reuse the excess which requires some kind of hood to collect it. Here was my setup:
I should note, too, that last July I did a trial run on the cassette box lid to see how this material would hold up. I picked that piece a) because I needed to repair it and b) it would get more wear than any other part of the car I would flock. Greasy elbow, spilled coffee, etc. It turned out to be more durable than I expected, although I will likely reflock it next year if I stick with this scheme. The dash should fair even better, since it gets almost no wear.
Some pics after flocking show how it turned out:
Note that I left the face of the pod unflocked, to match the console and glove box lid. I resprayed all those surface with a light coat of SEM vinyl paint which worked really well this time. I figured flocking everything would make the interior look something like that of a house of ill repute...
And finally everything (sans glove box lid- under repair when I took the pic) in the car (and note those cunning gauges!):
I know this isn't exactly to everyone's taste (heck, it isn't exactly to my taste, for that matter) but until I can afford to do a Fraggle and get a nice Rob Budd dash it will do nicely. I just spent 3 very pleasant days behind the wheel, 1275 miles, and having a rebuilt suspension and a redone interior made those hours very pleasant indeed!
Stan, thanks for the compliment,
So far so good, but I'll post a pic or two to show how the cassette lid held up.
"Too addictive..."???? That would be your avatars IMHO... Then again, maybe I'll flock the tires....
