Leather upper lid liner
My 1984 came without the leather upper lid liner on the sun roof. It seems that I should be able to fashion a replacement easily enough, but I am not certain how the liner is attached to the sun roof. There are three steel arms about 3/8" in width attached to the sun roof. Do these hold the panel, or is it clipped on some how? If the arms hold it on, are there sleeves on the panel for the arms to slide into?
Joe
Joe
You might want to look at PET to confirm what parts are supposed to be there, but FWIW, my '89 sunroof has a sheet metal panel to which the leather and foam backing is attached. This in turn is held to the outer sunroof panel by three screws along the front edge, and is pressed downwards when installed by the long metal fingers that you described.
Lots of detail pix here:
Sunroof Fix
http://forums.pelicanparts.com/porsc...ml#post6261411
https://docs.google.com/file/d/0BzvF...F3VVA0OWs/edit
Sunroof Fix
